RCU Forums - View Single Post - Hangar 9 Twist 3D
Old 07-02-2004 | 07:19 AM
  #316
ghee-grose's Avatar
ghee-grose
Default RE: Hangar 9 Twist 3D
Did you mount your engine at the recommended position, or did you put it as far forward as possible?
I found a tip on mounting your engine last....that way you can move it either way a little to ballast it...then you might not have to add any weight. I didn't add any to mine.
