RCU Forums - View Single Post - Vacuum bagging system recommendations
Old 07-17-2002 | 05:59 AM
TRP
Default Vacuum bagging system recommendations
Here is a shot of the other side.
You can see the solenoid / check valve. It had an extra port that I didn't need.. so I capped it off. I suspect this is where my leak resides. I don't think the screw I plugged the hole with was big enough
