RE: G26 in H9 Taylorcraft
The Saito pulled the TC in the same manor as the G26 did, slow and scale. With the Saito you can go through 16 ounces of fuel in 6-7 minutes with G26 I can fly for 20-25 minutes of the same 16 ounce tank.
Remember this plane will tip the scale at 16.5 pounds and the 2 engines will have around 12-14 pounds of thrust depending on prop size.
Don’t mistake my feelings towards the engine in a negative way. I like to fly the TC like it was intended to fly, Sunday slow flyer for some R&R…
