One guy on here sanded his flywheel fins off by mounting the flywheel in a drill press.
That may be in reference to a pic post I did awhile back....I put an arbored cutoff disc in the chuck and the flywheel on level table, and rotate the flywheel; 4" wheel works better than 3"
Deadeye Where did you get the engine? I'm considering HarborFreight's offering at $109. Don't like the sound of the carb mounting problem.. What series is your saw?
W8ye: Does the pic shown here give you enough to tell which carb setup may be on it?
This shows the color scheme on HarborFreight saw? Can anyone tell which carb setup it may have?
http://www.harborfreight.com/cpi/cta...temnumber=9967
