RCU Forums - View Single Post - RC10gt
Thread: RC10gt
Old 07-05-2004 | 09:03 PM
Frost_'s Avatar
Frost_
Default RE: RC10gt
ORIGINAL: HPIDUDE
if you can get a .26 in a GT show us a video
ALSO you said:
...you have a point there, but he's not going to get anything bigger than an .18 in it. I see you found the spell check button too
WRONG!
New era models makes the .21 conversion kit for the RC10, here is the link, see for yourself:
.21 to .26 Conversion Kit (Team & RTR) for Threaded Shaft Engines
http://www.neweramodels.com/cgi-bin/...chg&part_id=17
21 to .26 Conversion Kit (Team & RTR) for (P) smooth shaft engines
http://www.neweramodels.com/cgi-bin/...hg&part_id=329
Motor Mount For .21 to .26 Engines. Includes Clutch Nut, Drum and 2 bearings for (P-Shaft) (Smooth)
http://www.neweramodels.com/cgi-bin/...chg&part_id=14
Motor Mount & Clutch Nut for .21 Threaded shaft engines
http://www.neweramodels.com/cgi-bin/...chg&part_id=13
The above links go to active sessions so....... If they don't work for you go here : http://www.neweramodels.com/prod28_factoryteam.htm
That will send you to the page with links to all of above, scroll down a bit.
