RCU Forums - View Single Post - clutch problems
Old 07-06-2004 | 05:02 PM
Frost_'s Avatar
Frost_
Default RE: clutch problems
Your throttle/brake linkage needs adjusting. With the truck not running, take off the air-cleaner and look at how far open the carb bore is. Now apply brakes. See how it closed? You need to turn the screw that opens/closes the bore (idle screw) clockwise to open it up a bit, then re-trim your radio. This way it won't close when you hit the brakes....
