Lanier Phantom first flight
I now have five flights on the f-4. Since this is my first speed plane all I can say is SWEEEEEET!!!. I have a OS50sx running an APC 10x8 prop, may try a 9x9? Went with Twin aileron servos S3010 all the way around with 6-volt system. Modified the steering linkage to fit within the cowl. Moved CG forward 1" to 5 3/4". I'm thinking about moving forward more to try and get to land more jet like with the nose up but i'm not sure thats a good idea? Installed Whistles to get that turbine sound everyone at the field has commented on how awesome they sound! Added 1/8" ply and 8-32 blind nuts behind the tail cones to make it easy to add or remove weight for quick CG adjustments.
The landing gear wire is to small, would bend on gentle landings so i'm going with 5/32" wire and robostruts all the way around. Fuselage is very weak just below the vertical stab, after two gentle landings the fin sheared away from the fiberglass leaving a 2" crack in the fuselage. I will of course be reinforcing that area with more fiberglass unless someone has any other options since I have never worked with that stuff.
Next project? well I sort of went nuts a few months back so here is what I have in the waiting
Patriot W/ JETT 50
Shoestring W/OS91
Delta Vortex / bruce thorpe engineering
Top Flite .60 Corsair kit W/rcv 90
AK models SU-27
Not sure which one to start with. Need help on this descion!!!
Mike
