RCU Forums - View Single Post - Control Horns
Old 07-07-2004 | 06:38 AM
AFSalmon's Avatar
AFSalmon
Default RE: Control Horns
Pick a control horn that will give you about 3/4" distance between the hinge line and the pivot point. Then use a servo arm that also gives you 3/4" distance and you will achieve 45 degrees of throw each way at 100% travel.
