Shahid & Foof..
Gents
...how are we ..? I had allways been a devout Futaba sort of chappie ...until a few weeks ago .... after going round servo data for what seemed like years, i whizzed out and bought 5 new 3010's...installed the little devils...set some throws ...rates etc ..checked linkages ...checked again ...measured control surface end distance " float" etc , etc .....took the 3010' out.
Inwoods are still selling JR DS811's for less than £20 ...
The 3010 is a standard hi-torque servo, no more, no less...Its recomended, as with the 3305's that you only run these servo's ONLY with NiCaD's....because of the high current drain.......the 3305's have a nicer gear set..but...@ twice the price... & they still aint Digital.
Shreded gears..
..Nah
..same gear set inthe 3001 as the 9001 wich is rated at 5.2 kg...again way above what the lovley Flip is going to ask @ 2.5 kg weight
.....[:-] 3001's @ 6v on a 1650 MaHr NiMh...worth a thought ...6v gives you the HP and 1650 MaHr..the fuel tank ...so to speak
