RE: ultrastick hardware junk replacement
Norb
as far as the hinges those usually do require epoxy instead of CA. I use the same hinges on most my larger planes and they work good. As far the firewall is concerned, what engine do you plan on installing? I helped a friend put his together and there was no need for any extra "shock absorbing" material.
In general I am using Dubro stuff for clevices etc and they work fine.
