RCU Forums - View Single Post - Thunder Tiger .46 pro troubles
Old 07-10-2004 | 07:48 PM
RichD's Avatar
RichD
Default Thunder Tiger .46 pro troubles
Been fighting an engine problem for days. Would not go to max throttle while in the air, intermitantly. Today, after the 4th dead stick in as many flights, I found the problem. The Bolt and set that screws into the carb body had worked loose, causing the carb rotor assembly to slide in and out of the housing. Now that its tightened with locktite this time, it is back to its normal screaming self
