RE: BT 109e engine mounting problem
Hello,
I have looked at the mount and where it may need to screw to the firewall but the holes do not correspond. Im not sure what you mean by the screws and the washers. I dot mean to be a pain but do you know of anywhere that info on this mount system? It looks as though that i will need to put in another plate to put the screws into.
I have the header that you are talking about. All i need is the tubing to the exhaust manifold.
