RCU Forums - View Single Post - GWS ZERO WHIPPED!!!
Old 07-12-2004 | 02:09 PM
Thrustline
Default GWS ZERO WHIPPED!!!
Well, after many setups and frustrations the zero is slicing the air, it is a great flyer and very agile, flight times around 21 minutes and screaming along about 60 to 70 mph.
I had to modify her alot,
"CG" as found by others at 43 mm from the leading edge next to the root. New motor setup-running an AXI 2216/26 with a 10/8 prop -9.6 v 1100 mah ni/mh, no rudder, but now that it flies so well, rudder will be added. Not the original, it is poorly shaped and not very effective as it is. plane covered in light cloth and painted, stops it from dinging and cracking on some of these gear catching grass landings. Wing incidence is off quite abit, it was too positve for my liking, so it was reduced 6 degrees. 4.5 degrees rt. thust and 1.5 down. Anxious now to try the corsair since it is a short nose moment aircraft too and start off with it the same way this one ended up to make it a smooth flyer.
