RCU Forums - View Single Post - Engine problems
Old 07-12-2004 | 07:47 PM
Ron Olson's Avatar
Ron Olson
Default RE: Engine problems
Could be. A leaky carb or the barrel of the carb isn't in there properly. I've seen the last one happen. The idle set screw was not in the groove. I've seen some weird things in my time with things messing up carb settings. I had a nitro truck that was sucking air in through the front bearing messing up the needle.
