RCU Forums - View Single Post - 6X Dual Elevator Problem
Old 07-13-2004 | 09:19 AM
Krysta
Default RE: 6X Dual Elevator Problem
Hi Dean,
From what you are saying it sounds like you need to set the percentages again. When setting these the first percentage screen you see will be for R/U, when you have this set to 100% you will then need to move the Aileron stick to the left, you will see the default 50% setting, while holding the stick to the left you will need to hit the plus key to set this rate to 100% also.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
