RCU Forums - View Single Post - Plastic Gyro Screwdriver
Old 07-13-2004 | 04:44 PM
-pkh-'s Avatar
-pkh-
Default RE: Plastic Gyro Screwdriver
ORIGINAL: reilly13
Secondly, those plastic screwdrivers for adjusting the gyro's....why not metal? Is this to prevent over "tightening" or is this an electrical issue?
Would using a metal screwdriver cause the above to happen?
They give you a plastic one because it's cheap... you can use a metal jeweler's screwdriver if that's handy. If you're not careful, I'm sure you can turn the little trim pot past it's endpoints with a plastic or metal screwdriver!
