Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 Plastic Gyro Screwdriver >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 07-13-2004 | 12:40 PM
Default Plastic Gyro Screwdriver
Two things:
My century PG2000IIR gyro is not working. I still have tail control with the servo, the light is on but it doesn't respond to movement. Nothing has changed other than lost teeth on the main gear on my nexus which caused the tail do some serious dancing. This has been fixed and now the gyro is not working. Changing the gain has no effect, am I missing something?
Secondly, those plastic screwdrivers for adjusting the gyro's....why not metal? Is this to prevent over "tightening" or is this an electrical issue?
Would using a metal screwdriver cause the above to happen?
I'm going to install a GY401 and don't want a repeat with this gyro!
Old 07-13-2004 | 03:04 PM
Default RE: Plastic Gyro Screwdriver
Anything that creates an oscillating electromagnetic field (especially if low signal levels are involved), can be influenced by a chunk of iron or steel nearby. You really see this effect in the receiver section of a radio. This is why "tuning wands" exist. These are basically plastic screwdrivers for adjusting sensitive circuits.
Old 07-13-2004 | 04:44 PM
-pkh-'s Avatar
ORIGINAL: reilly13
They give you a plastic one because it's cheap... you can use a metal jeweler's screwdriver if that's handy. If you're not careful, I'm sure you can turn the little trim pot past it's endpoints with a plastic or metal screwdriver!
Old 07-13-2004 | 10:05 PM
They're plastic, as -pkh- said, because it's cheap to make and also so it can be snapped onto your TX's handle so it's always handy. I lost mine a while ago and use a small jewelers screwdriver to adjust it.
Regards,
Mike
Old 07-13-2004 | 10:30 PM
-pkh-'s Avatar
ORIGINAL: ChopperMike
Regards,
Mike
So that's where you're supposed to snap it onto! I knew it was made to snap onto something, but didn't know what it would fit onto!
Old 07-19-2004 | 01:35 AM
The hele should be turned off anyway when ajustment is made so no electrical static etc would effect it.
Also gyros only use the new settings of the pots after they restart. i think 8)
Old 07-19-2004 | 06:21 AM
Mine doesn't (GY240). I never shut it off before I adjust it.
Old 07-19-2004 | 06:45 AM
lawnhawk's Avatar
Plastic screwdrivers for adjusting gyros and speed controls do not exist because of cost.
They are to prevent the servos from twitching from interference when the two metals meet. I personally would not want my throttle servo dancing around when I'm trying to adjust the gyro. I have also seen recommendations to use plastic when adjustting your low speed carb needle too.
Old 07-19-2004 | 08:44 AM
-pkh-'s Avatar
ORIGINAL: lawnhawk
Umm... exactly what "interference" would this be???
A plastic screwdriver would strip out before it even budged my low speed needle!
Old 07-19-2004 | 05:51 PM
Exactly. Try adjusting the idle mix on the OS 50 with a plastic screwdriver. It's hard to turn with a metal screwdriver. And what 2 metals (re gyro adjustment) are we talking about? The adjustment pots on your gyro aren't metal.
