RCU Forums - View Single Post - Ignition - Brison 2.4
Old 07-14-2004 | 01:42 AM
GalenB
My Feedback: (18)
Default RE: Ignition - Brison 2.4
Have you run the engine? Is there something wrong with the ignition? I've got several Brison engines and the mechanical advance works just fine... If you change ignitions you'll need to replace the hall effect sensor as the stock unit is on the rotating ring...
