RCU Forums - View Single Post - Voltage increasing regulator component
Old 07-14-2004 | 06:33 AM
elevator_up
Default RE: Voltage increasing regulator component
Thanks Rodney but this does not answer my question. Does anyone recall the post I am referring to or have info about the type of component/device I am looking for. My application is lowpower and size is not a primary concern as it would be to power my plane cam.
If nobody recalls the post ...
Does anyone know the name of some components that will raise the voltage of a battery, similar to a voltage regulator, but raises the voltage, instead of drops it. So a 3.7 lithium could power a 6 volt device (but at less efficiency). I seem to recall in the original post the unit was something like a transistor or a 6 pinned IC, and you needed to add a capacitors as you increased voltage. Anyone know of it or something similar ?
