RE: Caliber .30 setup
it get's rather confusing, because futaba sr3 swash is 60 180 300 and caliber is 0 120 240.
so you have to read both caliber manual and futaba manual carefully, and do a very hard thinking to sort things out.
9c has servo reverse but that's not the only thing. there is "SWASH AFR" that also does something similar to servo reversing and also does mixing adjustment. which you need to use to set up 0 120 240 type swash.
read the page 79 on your 9c manual carefully.
at the end, you need to recheck whether the movement of swash corresponse to the movement of your tx sticks.
