RE: SIG komander cowl??
OK...Thats it....next project is a Kommander MkIII:
Low drag symmetrical airfoil wing with bigger ailerons
Bigger built up stick vertical stab and rudder
Built up stick stab reworked to move elevator hinge line forward
Move elevator down in fuse to reduce pitch coupling
OS .91FX
Retractable gear
I have a buddy with a foam cutting rig that will cut cores, I can carve a plug and make a nice fiberglass cowl...
Construction begins as soon as my Little Toni Arf is done.
What do you think?
