 SIG komander cowl?? >
SIG komander cowl??
SIG komander cowl??
Old 07-08-2004 | 11:33 AM
Default SIG komander cowl??
Hi I'm looking for a Sig Komander cowl..The kit has been discontiued..Contacted Sig none there.
Help Dan
Old 07-08-2004 | 11:49 AM
Warren's Avatar
My Feedback: (72)
Default RE: SIG komander cowl??
As I recall, it is the same cowl they use on the Sig Kougar?
Old 07-08-2004 | 01:11 PM
My Feedback: (13)
I got a fiberglass cowl for the Kommander a couple of years back from Fiberglass Specialties.
www.fiberglassspecialtiesinc.com
I see they still have it listed on their web site.
The cowl is an SK-23 for $24.00.
Greg
Old 07-08-2004 | 10:15 PM
Charlie's Hobbies (Tampa FL 813-882-4007) has a Sig Komander cowl. I was looking at it today. I loved the looks of that plane but got into the hobby too late to get one. I'm sure Charlie would ship it to you.
Old 07-12-2004 | 11:54 AM
The Kougar cowl is 1" shorter in the width..I have that plane also..The Komander cowl is needed for a scratch built Cloud Dancer..The firewall is 3 3/4"..FS ddoes have one they want $24.00 + shipping.. The short kit for the CD was only 24.95..
Old 07-12-2004 | 02:12 PM
Call Charlie's Hobbies he will sell you the Komander cowl for less than $25.
Old 07-12-2004 | 05:08 PM
HI Adrain
I called the store for the Komander cowl..They couldn't find one..They had a Kadet cowl.
Dan
Old 07-12-2004 | 07:10 PM
Hmmm...I'll go by there tomorrow at lunch. I saw it last week. It has to be there. They do have a ton o' stuff though and the Monday guys may not know what to look for.
Old 07-12-2004 | 08:26 PM
JNorton's Avatar
DBono99
"The short kit for the CD was only 24.95.. " WHERE???? If you don't mind me asking?
John
Old 07-13-2004 | 08:54 PM
blw's Avatar
blw
Isn't the Kommander the forerunner to the Kavallier?
Old 07-13-2004 | 10:34 PM
They were out at the same time. The Kavalier was a 35-46 size plane and the Kommander was 46-60 size.
Sure enough someone bought that cowl...sorry..
Old 07-14-2004 | 11:50 AM
OK Thanks for trying
Dan
Old 07-14-2004 | 07:33 PM
blw's Avatar
blw
The Kommander is a nice looking kit.
Old 07-14-2004 | 10:07 PM
Sport Flyer's Avatar
My Feedback: (10)
I've built three Komanders. Great second plane choice or everyday sport flyer. Nice looking and nice flying, while looking a bit more spiffy than the Kavalier, imho. There is a definite weak spot with the canopy though in that the back of it is unsupported where it sits over the wing. Mine all would develop cracks at the edge where the canopy was glued to the fuel tank hatch. Might be an issue for someone if Sig no longer stocks them.
Old 07-15-2004 | 08:18 AM
blw's Avatar
blw
I don't know which I would have built if the Kommander were available. The Kavalier main gear will probably last longer even though I like wire gears better.
Do you still have a Kommander?
Old 07-15-2004 | 08:56 AM
I always wanted to build a Kommander and do it up in a late 60's Navy scheme. Unfortunately they were discontinued before I was old enough (had enough $$) to get into the hobby.
Old 07-15-2004 | 09:29 AM
My Feedback: (10)
Never had a problem with the Komander gear legs when flying off a decent flying field. They'd rake back a bit after a few grass landings but that was easy enough to straighten. My first Komander died on its first flight thanks to a deadstick in high winds. The second was sold after 3 years of heavy flying and some pretty bad fuel creep under the covering. The third was sold four years ago. I was flying off a cow pasture then, and had changed the landing gear to a dural blank mounted on the fuselage after I had cartwheeled because of catching one of the gearlegs in a gopher hold on landing.
My brother has a Komander Mk I kit in his basement that I just might take from him one day.
Old 07-15-2004 | 10:54 AM
OK...Thats it....next project is a Kommander MkIII:
Low drag symmetrical airfoil wing with bigger ailerons
Bigger built up stick vertical stab and rudder
Built up stick stab reworked to move elevator hinge line forward
Move elevator down in fuse to reduce pitch coupling
OS .91FX
Retractable gear
I have a buddy with a foam cutting rig that will cut cores, I can carve a plug and make a nice fiberglass cowl...
Construction begins as soon as my Little Toni Arf is done.
What do you think?
Old 07-15-2004 | 09:07 PM
Adrian, I have only one thing to say to you, PICTURES!! That would be a very worthy project. Well worth the effort. Just share it with the rest of us SIG fans. Good luck with it.
Mark Shuman
Old 07-16-2004 | 09:36 AM
blw's Avatar
blw
Here are pics of 4 Kommanders: http://home.merlin.mb.ca/~kmartel/projects.html
The Kavalier: http://www.rconline.ca/hangar/hangar...=Fran%C3%A7ois
Old 07-16-2004 | 10:37 AM
My Feedback: (10)
blwblw, those Komanders would be mine. Thats my original homepage.
Old 07-16-2004 | 07:34 PM
blw's Avatar
blw
Sport Flyer,
I thought they were yours from your comments here and on the website. Those are very nice looking planes.
