RE: 4 * 40 with a Saito 56
All you have to do is rotate the throttle arm so that when the carb is closed it stops before it hits the firewall. Then just get a piece of 2-56 rod with threads on one end. Run the threaded end past the arm on the carb then bend it back towards it. Attach a nylon clevis and your set!!
