4 * 40 with a Saito 56
My Feedback: (32)
ORIGINAL: Redrum
I had mine mounted vertical..This engine is an excellent match for the 4*..Your gonna love it..
Thanks for your reply though, it sets in cement what I want to do and that is the Saito instead of the OS 46AX (which I know is another great engine for this plane, but thats another story.
Bill
My Feedback: (61)
NJ
All you have to do is rotate the throttle arm so that when the carb is closed it stops before it hits the firewall. Then just get a piece of 2-56 rod with threads on one end. Run the threaded end past the arm on the carb then bend it back towards it. Attach a nylon clevis and your set!!
My Feedback: (145)
You could drill a hole through the motor mount and use a flexable cable.
You can rotate carb throttle arm 180 degrees that would put your arm higher.
You can go past the throttle arm and make a U in the push rod and come at it from the front.
You can mount a bellcrank on the motor mount and attach the pushrod to it and the other end you
can connect anothershort pushrod to the throttle arm.
I have used all the above. Somethimes a
4 stroke can be a PITA.
My Feedback: (16)
CA
Bill,
The owner of a LHS sold me the Du-Bro 4 stroke linkage. This lingage consists of a single arm of a belcrank that will attach towards the front of the engine mount. The throttle cable from the servo attaches to the arm. The arm has a positive link (2-56 rod) to the throttle arm. the Du-Bro kit contains everything you need to attach the product to the kit. It provides the optimum amount of slop to enable the throttle arm to move inwards/outwards when opening/closing during operation. It cost 3.95
The other method that he suggested, is to take cable and put a U into it and solder the U to prevent future bending. The cable will have a clevis threaded on, and then attached to the throttle arm.
Lew B
Lew B
If rotating the throttle arm will not allow it to clear the motor mount, take a piece of 2-56 pushrod and make a bend so it will clear the motor mount. Drill a new hole where needed and plug the old hole with a piece of dowel.
The special adaptor/linkage is normally not needed for a 4 stroke since you can reverse the servo to get the proper movement.
