RCU Forums - View Single Post - saito 100 problem
Old 07-17-2004 | 06:35 PM
timothy thompson
Default saito 100 problem
I broke one of the mounting lugs off the engine. I inserted and tightened down the three remaining bolts seems solid then I took an oversize washer and bolted it into the spot where the lug is gone. I then filled the cavity with JB weld this stuff holds well and can be drilled like metal. I hope it will hold what do you think
Tim
