RCU Forums - View Single Post - Kyosho G Trick 90 Hinges
Old 07-18-2002 | 03:50 PM
swill
My Feedback: (17)
Default Kyosho G Trick 90 Hinges
Kirk,
On my G-Trick, I have the same setup. Altough I replaced the funky metal hinges with Du-Bro pinned hinges, and also used the CA hinges where they stated. I actually like this setup... works great. And I have a little reassurance as the CA hinges help hold the control surface on should the others come loose (which won't happen if you pin them).
It's a good flying plane - if you have any other questions, let mek now.
I have a YS 91 FZ on mine with a 14 x 8 APC. Tru-Turn spinner.
Good luck,
Scott
