RCU Forums - View Single Post - saito 100 problem
Old 07-18-2004 | 01:08 PM
voyager_663rd
Default RE: saito 100 problem
for what it's worth, I buried a 46 and the rear needle broke off (well, the "flange" that is part of the back plate that holds the needle). Super clean, I jb'd it. It lasted maybe 20 flights then it broke again (ie: the "weld" didn't hold) just from normal vibration, needle-twisting usage.
Do it and it might work for a while. Just keep checking it to make sure it is holding as you want it to.
