Aw 60/90540t
I wanted to get started in IMAC and Possibly 3D. After much research I have decided on the AW 60/90 ARF. I have scanned all of the threads and made some decisions and have some questions as follows:
1. I plan to use an OS 1.08
What Prop should I use?
What type of in Cowell Muffler should I use or can I use the stock muffler?
2. I plan to use 2 Hitec HS255 on the elevator, positioned in the rear as per the updated on AW's web site.
I plan to use 4-40 rods on these, what type of cleveses and servo arms do you recommend?
3. I plan to use a Hitec HS 625MG on the rudder(94ox torq at .15 sec at 6 Volts).
What servo arm should I use?
Is the pull pull system with the Kit ok?
4. I plan to use Hitec HS525MG(57oz torque .13 sec at 6 V) on the alerons.
What pushrod/clevase do you recomend?
5. My radio is a Hitec Eclipse 7ch.
6. I plan to use a Hitec HS 81 on the throttle
7. Should I replace the factory gas tank?
8. I'll buy a pilot, scale inst pannel, and wingbags from AW.
9. I will be installing tail wires.
10. I will start with the CG at 4" and slowly move to 4 1/4".
11. I will run a 6V 1000 mha rcvr pack with a safety switch 5.7V regulator.
12. What Have I left out? What else would you do? What would you do different? It there anyone out there that has flowne a 60/90 with a OS 1.08?
PS: I have a greatplanes 40 Size ARF with a Saito 100 on it, talk about overkill
