RCU Forums - View Single Post - Plan For a 3D?????
Old 07-19-2004 | 05:56 PM
BasinBum
Default RE: Plan For a 3D?????
ORIGINAL: bikz
well i'v seen this particular model by Wattage called the Live Wire and it flies awsome.
its a bit expensive so i was wondering if i could build one since the construction doesnt look too difficult.
so thats why i wanted to know if there is a site like those made for foam planes but instead on different matterials for an electric.
this is the site for Live Wire:
http://www.globalhobby.com/public/wa...ery/128435.asp
If you think the plane is too expensive forget about it. There is nothing cheap about setting up a foamy for 3D. Brushless w/ ESC, lipos and mini receiver and servos will cost about $300 so the 20$-80$ you could spend on a plane is the least of your worries. Some will say you can do it cheap with a brushed motor and nicads but you won't have a 3D machine like you read about in the forums. My Foamy Factory blows people away at the field and I only have $20 into it before the electronics. When I tell them what it'll take to set up they lose interest real fast.
