Plan For a 3D?????
foamyfactor.com, 3dfoamy.com, rcxplane.com just to name a few.
Mark
Mark
ORIGINAL: bikz
Is there any website where i can find any plans to make a 3D foam plane?
thanks.
thanks.
here [link=http://www.foamyfactory.com]foamyfactory[/link]
and here [link=http://www.3dfoamy.com]3dfoamy[/link]
i think 3dfoamy is the best but it takes a while to figure out how to download the plans.
alright....checked out those foamis......
are there any sites for planes made out of polysterene?
need the planes to look a bit more 3D!!!
Look a bit more 3D? Why would you want that? Then they don't perform 3D well anymore? Polystyrene will not work well. Much too fragile for anything. And when you get it more sturdy you add too much weight.
well i'v seen this particular model by Wattage called the Live Wire and it flies awsome.
its a bit expensive so i was wondering if i could build one since the construction doesnt look too difficult.
so thats why i wanted to know if there is a site like those made for foam planes but instead on different matterials for an electric.
this is the site for Live Wire:
http://www.globalhobby.com/public/wa...ery/128435.asp
Looks a bit like a balsa model from what I can see in the pic. It is a little difficult. You could of course try several other foam products. Some guys are having success with blue foam and such. Do some research here and on the sites. You should find something that will work. Like us guys here in SA are forced a bit to use an extruded foam. It is used to make iso boards. This stuff in particular is quite light but very fragile as well. Does work for a foamy I suppose but it will not take the beating depron will.
NC
Hey guys check out 3drcplanes.com they got an awesome sukhoi that is so easy to hover u can do it with one hand, you can also get the eflite ultimate and tribute from them to!
P.S. thats me on the front page!
the watt-age livewire is on sale right now for only $30!!! www.hobbypeople.net
Hi Friends,
This is a drawing of a Foamy Bipe it is awesome Foamy plane, my setup is Hacker B20 15L 1.200mah 3S Lipoly! good Flying! Ciao Alfo[sm=spinnyeyes.gif]
The Server don't permit me to attack dxf file if you are interest in plane send me a mail at smia@mclink,.it
ORIGINAL: bikz
