ORIGINAL: tIANci
Pressure line - upper hole, metal tube is bent upwards a little
Fuel line - middle hole, leave the metal tube straight
Refueling - lower hole, bend the metal tube downwards a little
When I say bend I mean the portion INSIDE the tank. Hope this makes sense.
Ok, got it, but the tank came with a 2 metal things that goes on the inside and the outside. They are circular and have 3 holes for each tube and a screw hole it the middle. why put these on? The rubber gromet is enough to keep them seperated right?
