RCU Forums - View Single Post - YS110 does not run
Old 07-20-2004 | 04:57 AM
Hans Meij
Default RE: YS110 does not run
Dave, when I try to blow (by mouth) through the fuel delivery line, there is not much resistance when the screw is flush.
When i turn the screw in, the fuel line gets closed when the regulator screw is turned 1/2 to 1 mm in.
At this setting when i apply some suction at the blue fuelline (the one that is between the regulator and the carb) the valve opens and air is admitted.
Based on these facts is perhaps for me the starting point for the regulator screw 1/2 to 1 mm turned in? Or doesn't it make sense what I'm doing here?
Regards,
Hans
Hans Meij / Modelvliegen
