RCU Forums - View Single Post - Saito 56 starting problems
Old 07-20-2004 | 01:53 PM
roarkr
Default Saito 56 starting problems
Hi,
I've mounted my Saito 56 inverted and it won't start. When I give it some fuel directely into the carb opening ( not the normal inlet) it starts, but stops within a second or two.
This should be (based on my engine knowhow) a fuel feeding problem.
When I prime the engine according to the book there are fuel all the way to the carb inlet, but it won't start.
The only way I can start it ( but it won't for more than a second or two)is to give it some fuel directely into the carb opening
The engine has been in store for some years after breakin.
The high-speed needle valve is set 4 turns out. The low-speed is factory set.
What could be the problem? Any ideas?
rgs, Roar
