RCU Forums - View Single Post - Symthoms of being alergic to CA glue??
Old 07-20-2004 | 08:10 PM
The Ghost's Avatar
The Ghost
Default RE: Symthoms of being alergic to CA glue??
I started to get a rash and small blisters on the back of my hands when I used CA. Seen my doctor and hat some tests done. Found out I became Hyper-Sensitive to CA, polyester & epoxy Resins. I was told not to use them for 12 months, Had more test done after and the sensitive levels had droped. I have gone back to using the good old white glues and use all the protective gear when using epoxy/polyester resins. I don't use CA's anymore. Just remember, If you become Hyper-Sensitive to the glues or chemicals we use you CAN NOT DO ANYTHING about it!!!!! except not use them. So you will not be able build or the possibility to fly. Just think about that. Follow the INSTRUCTIONS that come with the glues.
Cheers,
Remember, Always look after the ORGANIC part of the model.
