RCU Forums - View Single Post - Building my first ARF's.....(Advice)
Old 07-20-2004 | 09:50 PM
RoNeRiC
Default RE: Building my first ARF's.....(Advice)
ORIGINAL: tIANci
What do u mean dented? If I think its what it is then use a hot iron on it, the dent will smoothen itself out. Set the iron to very warm, you can just about touch it with bare fingers. Then iron it, take the heat up slowly until you see some results. Also, once the yellow coverig turns dark yellow you know that you are reaching the threshold of scorching the covering.
Dented pretty good. It almost went through. I'll have to borrow somebodys iron to see if it will come out. It's not a slight dent, it's a pretty good one.
