RE: how should i pull the aileron servos leads on a widebody 40?
The ply rib makes good sense. Also, extra ply for the fuselage bottom and nylon bolts for the main gear.
Do the foam parts come sheeted with balsa? The website is confusing on this. I assume they do the sheeting at the factory.
Does the engine have to be inverted for thrust lines?
