RE: ok few more questions b4 first kit
You don't have to use CA if it won't bond or you have probs with it. I use CA on some sticks and tightbond II on others. If you don't have a miter it will be tougher to get your angles cut correctly. Build to the plans then fill gaps with poly, wood or med/thick CA.
