 ok few more questions b4 first kit >
Old 07-21-2004 | 10:36 PM
Default ok few more questions b4 first kit
hey guys,
as you know i will be building a profile kit.
pretend like i know nothing what could i forget to do without someone telling
so you take the sticks of balsa cut them at the angle the plans call for then sand them and CA them in place?
with medium CA ? correct.
im just affraid im missing something big thats obvious and i am affraid im gonna screw it up
thanks for the tips to come
Felix
Old 07-22-2004 | 01:01 AM
tailskid's Avatar
My Feedback: (34)
Default RE: ok few more questions b4 first kit
Yeah, sort-of.....when you make those cuts make sure they are perpendicular .... and apply glue to both pieces before joining them. Don't use any kicker and you should have a tight joint.
Also, glue the parts over waxed paper which is over the plans!
Jerry
Old 07-22-2004 | 01:07 AM
You don't have to use CA if it won't bond or you have probs with it. I use CA on some sticks and tightbond II on others. If you don't have a miter it will be tougher to get your angles cut correctly. Build to the plans then fill gaps with poly, wood or med/thick CA.
Old 07-22-2004 | 01:21 AM
where can you find little miter hobby knives or mini saws ?
can you find them at like home depot or any other place
i dont have one and i saw one in a store once that had the part that you could change for the angles and then a long hobby blade in the middle that would cut the balsa
thanks
FElix
Old 07-22-2004 | 06:17 AM
MinnFlyer's Avatar
Felix, get a razor saw. Most Hobby Shops, or Craft stores will have them.
Do you have any flying buddies who build? Might be a good time to invite them over for a beer
Old 07-22-2004 | 09:46 AM
why use medium CA? if you check your joint angle for proper fit, just go ahead and use the quick Ca, what ever you use, go slow on the kicker- hardens the glue, makes it brittle and can produce a weak joint. an awful lot of models have been built and will continue to be be built with good old fashion tools. the $$ for the fancy tools can better be spent on balsa and more kits. OLD TIME BUILDER, since 1930's. dick
Old 07-22-2004 | 12:47 PM
hey guys
i do have a razor saw just nothing nto get angles perfect with
is aa little mitre box plenty?
or are there more weird angles than 45 90 and 30 ??
thanks
Felix
Old 07-22-2004 | 01:53 PM
make sure your building surface is flat, or even.lol
get weights
use sanding blocks ,bars..ect.
wood grain going in the proper direction.
get a triangle and cut the 90 deg coner off...for verticle stab alingment.
measure twice...cut onces.lol
have extra balsa or tristocks ..incase you deem certain
area needs re-enforcement... or you goof.
do inventory first before building.
mark parts and sort to building sections or sequent.
this will help alot .
Old 07-23-2004 | 07:10 AM
MinnFlyer's Avatar
Don't worry about the miter box. 99% of your angles won't be 90 45 or 30.
And if you're off a little? Why do you think they make medium (Gap Filling) CA?
