RCU Forums - View Single Post - ok few more questions b4 first kit
Old 07-22-2004 | 09:46 AM
dicknadine
Default RE: ok few more questions b4 first kit
why use medium CA? if you check your joint angle for proper fit, just go ahead and use the quick Ca, what ever you use, go slow on the kicker- hardens the glue, makes it brittle and can produce a weak joint. an awful lot of models have been built and will continue to be be built with good old fashion tools. the $$ for the fancy tools can better be spent on balsa and more kits. OLD TIME BUILDER, since 1930's. dick
