RE: New Pattern Plane?
Hi Folks
I have just flown my Fascination. I fly pattern ships this is a great flying airplane. The only thing I had problems with is the land gear block. If you have some time I would beef up that area because it is weak. If you have a tough landing the gear is going to depart the airplane. Also the engine mounting system was a little tough because you had to line it up with the cowl there was no guide holes in the fire wall. I put a ys 53 on the airplane.
It trimmed out very easy.
The airplane is great for a beginner in pattern. It would work great in sportsman classes.
The plane flies true and straight. The starting throws are right on for my like.
Ron
