RCU Forums - View Single Post - Sig 4 start GRIEF!!!!
Old 07-22-2004 | 01:14 PM
raideron's Avatar
raideron
Default RE: Sig 4 start GRIEF!!!!
hookedonrc.. Yeah I was going to use yellow.. I think.. But
that's the reason I got the ARF Red.. I thought you can't help
but see it... I was thinking of just re-sheeting three or four
ribs worth kinda in an angle starting from the first sheeting
rib at the fuse end. Then maybe a white top/yellow bottom
on the L.E. up to the next spar.. And something on the fuse..
May be I should have put the fuse star decal on the fuse
instead of using it with the wing star... Windex method?? So
you used the sticky backing stuff instead of ironing on???
Shok.. Full hover @ half throttle... I can hold my hover for
quite a while, But I start at better than half throttle and end up
at full throttle:-( I thought the Mag 91 4s would do better than
that with 14x6 prop, I'm going to try a 14x4... Trying to find if
I can run a 15x3??? But I'm still running it rich..So maybe it'll
get better.. Ofcourse I'm doing this 20 mistakes high... I'm still
a "BIG" chicken:-)
