I am thinking of using approx 4 lb cylinder. So I need an adaptor that fits the larger cylinder and with threads at other end to fit my pressure regulator . BTW are the pressures of the refillable cylinders same as the BBQ cylinders? Tks
Why so large? The cylinder in the photo is only 0.34kg more than enough for a days flying. I just refill at home from a 25 Lb bottle.
Cheers,
