RE: Savage Items Required?
Cant go wrong with 20%. As for starter box Im assuming that your taking about the ROTO START unit. Not the start boxs for buggies or onroad cars right? Dont think the Losi spin starter will work with that engine. Has a different shaft than the HPI Roto start unit. If you get the RTR savage, it will come with the ROTO START for the engine. The roto start has a shaft that is inserted in the backplate of the engine. Cranks up the motor while you heat up your glow plug with your ignitor. No need for pullstart mechanisms. And as for tuning. "YOU" the racer has to tune the engine. Not the starter. Hope this helps.
