RCU Forums - View Single Post - Ram750F
Thread: Ram750F
Old 07-22-2002 | 11:21 PM
Dave Matthews's Avatar
Dave Matthews
From: out country, somewhere, US MINOR OUTLYING ISLANDS
Default Ram750F
Hi,
For the Start box question the vales do exactly what you say and this is normal. The gas valve moves in all directions and the air goes up/down.
Any Propane will work. Collman tanks fit the supplied gas valve.
As for the battery. you need 5 cell 1,400 mAh or higher if you wish. The connectors can be got via www.farnell.com and are Made by Anderson Power Products. The connectors are rated @ 15A to 120A.
Hope this helps.
Reagrds,
