RCU Forums - View Single Post - Welcome CEN Racing!
Old 07-25-2004 | 12:05 PM
gofaster72
Default RE: Welcome CEN Racing!
Does CEN make an assembly manual available for the mt2? If you are a driver and not a builder, this kind of leaves you in the dark when it comes to doing repairs. I have hit something while sliding in a left turn and it has partially pulled the lower left rear ball joint out of the control arm. This then let the axle shaft fall out of the chassis. If I fix or replace the control arm at what depth should the ball be set in the backing plate to give the correct running clearance, or end play, to the ends of axle shaft? Need a little help here, THANKS . . . . . . .
