RE: GSP 72" Extra tip stalling
Sounds to me that there is excessive elevator movement causing the flick (doesnt sound like a tip stall), especially if you are pulling out of a loop... Try reducing the throw slightly and see if that helps? Also, check that the lateral balance is ok from prop shaft to tail..
