RCU Forums - View Single Post - Hangar 9 Twist 3D
Old 07-26-2004 | 08:23 AM
  #377
Hot Rod Todd's Avatar
Hot Rod Todd
Default RE: Hangar 9 Twist 3D
The same spin you mention is used in the blenders I do. Go high, and head straight for the ground with left aileron. Pull both sticks to the lower inside (Full right rudder, no throttle, full left aileron, full down elevator) Feed in power, and less elevator, and adjust ailerons for a flat hanging spin. They make for an impressive manuever.
