RCU Forums - View Single Post - O.S. 46 FX ON A TRAINER?
Old 07-26-2004 | 08:31 AM
Fastsky's Avatar
Fastsky
Default RE: O.S. 46 FX ON A TRAINER?
The 46FX will be a nice change for you. Don't go smaller than a 11" prop. It will makes lots of noise and not give you the benefit of the larger engine. I tried lots of different props on trainers with 46 engines and found the best choice seems to be a MAS 11-5. It will give you lots of pull to get you out of trouble if you need to and will act as a brake for easy landings. It will also give the trainer respectable speed for cruising. You won't be sorry. [8D]
