RCU Forums - View Single Post - Top Flight ARF Flight Streak
Old 07-26-2004 | 09:07 AM
Ryan Nau's Avatar
Ryan Nau
My Feedback: (54)
Default RE: Top Flight ARF Flight Streak
On the landing part, it may sound like you stalled the plane. Keep up your airspeed until your ready to set it down, and then slow it up a little bit. Another thing check to make sure your wheel moves smoothly. I didn't use the stock wheel on mine, it flexed down to much. Yes the fuse on the ARF streak is hollow. I had problems with mine at first. I used a starter on it and it broke the front off where the wing is. I braced it up with some more wood, and some of the Brodak Hinge material with CA. It makes it very, very stiff. I ran it back to the wing. Now its really stiff and dont have to worry about it breaking. Its as strong as a solid fuselage.
Ryan
