G-202 split flap configuration
Depending on the type of flying you will be doing, you could spit the aileron at the 30% mark and have the inboard for flaps. Put 4 servos in the wing (2 inboard panel) ( 2 aileron) then if you want to use the entire surface as aileron, you can do it or if you decide to use the inboard as flaps, you can do that as well. It will act a lot like the H9 Stick. You should be able to crow and a lot of other maneuvers with the Giles
